Jermsy
Howdy,
my dad had an engine swap done on his 2006 jeep liberty 3.7. Donor vehicle was a 2003 Jeep liberty.
He immediately started getting codes p0016 and p0344 and decided to just give me the vehicle instead of messing with it any further.
I've pulled the valve covers and lined up tdc and my timing is spot on.
Both cam and crank sensors are brand new mopars.
Wiring is fine.
I've done everything except run a labscope to check the voltage pattern - only because I don't have access to a labscope.
I know the cam reluctor wheels are different on the 2003 and it looks like it's still got the 03 reluctor running with the 2006 pcm.
I'm wondering what my options are.
Could I just pull a pcm out of a 2003 and plug and play in the 2006?
Would it be better to swap the reluctor wheel to the newer style - is the crank wheel different as well? (albeit way more work)
Any help or insights are appreciated.
Dealerships in the Fort Worth area aren't being any help because it's apparently old chrysler tech that no one uses anymore.
Wiring is fine.
