have changed remote battery didnt work.mine is quite different from the picture. its the remote button on the key. tried the hard reset didnt work too.Have you checked the key fob for any damage or corrosion & test the FOB battery voltage?
Takes two CR2016 batteries or should read over 3 volts each or over 6 volts in total.
Also could try doing a hard re-set.
Take off both battery cables, and tape or clamp both battery cables together, isolated away from car battery, for 40 minutes & then reconnect both cables to the battery correctly.
The keyfob battery is a 3 volt 2032. Do not use 2 x 2016 (6v)I replaced 6, 33 & 34
