offroad cowboy
Can i fit 15 in wheels on a 06 limited ?
sent by telegraph from my k30
For that combo you must install a lift 1st.Absolutely have to be lifted to run 15" wheels on the KJ? I was looking at getting some and 30x9.5 instead of getting stock sized tires when my current tires need replacing.
The backspacing of 4" is the only thing allowing the fitment of a 15" rim otherwise they would hit the brakes and tie rod ends that you will get on OEM steel rims that have 5.5" of back spacing.Gotcha…thanks. Wish the Soft 8's came in a better backspacing
Would a 4.5" backspace work on a steel wheel with a 31x10.5x15 with an Ironman 2.5" lift? or would you need the top plate, clevis and iso's added?
