recently lifted the jeep 2.5". Now I'm looking for new tires and rims, I want 31x10.50 but don't know if I should get crager soft 8's in 15 or 16
I did a full suspension lift with ome springs an bilstein shocks. I found a really good deal on a set of 16x8 wheels with 245/75r16's with 4.5 inch of back spacing. will those work?
the deal I found is 4 vision 16x8 85 soft 8's with 4.5 backspace and 4 brand new goodyear wrangler duratrac for around 800 which is good for where I live. are they worth getting and running. could I just run a 1/4 or 1/2 inch wheel spacer or is that an even worse idea
Adding wheel spacers makes it even worse spacing the tire and wheel combo out even more
What size Duratracs ? If you you must run 8 inch wide wheels
then 255-70 or 265-70-16s sit much better on an 8 inch wheel
of course will lose power anytime you get up into that size along with gas mileage unless you regear
245/75R16 Duratracs already mounted and balanced
Well good luck, all you can say at this point I guess
need to stop wasting my time
you're the one asking what size they were.... I haven't even bought them I meant the duratracs are already on those wheels
