Some of you may remember my saga over the winter, in which AZ gave me the wrong starter twice. Well, today the Liberty decided it didn't want to start again. Started fine first thing in the morning, started fine around lunch time, and then when I went to leave a site, it wouldn't start. Starter isn't even attempting to run. It's acting like the clutch pedal isn't pressed. I tried starting it in 4LO, and that didn't work. Got it pop started and drove home. The clutch switch appears to be working fine. I swapped the starter relay with a different one that I know was working. I don't think it's the ignition tumbler because the clock turns off when I turn the key to start. Before I pull the starter off again to test it, is there something else I should be trying?
2003 Libert 2.4L.
2003 Libert 2.4L.
