Hello all, I'm new here and I must admit I'm at wits end. The other day I stopped for breakfast on the way to work. A few minutes later I came out, put the key in the switch, turned it, the dash lit up the radio came on and nothing. A few things I know for sure. The key switch actuator is fine. Ive already had it out and its not broken. I've had the starter off and it bench tests good. the starter relay is good. The start fuse is good. There is 12 volts at the battery cable to the starter. STRANGE BEHAVIOR--- The starter signal wire has 12 volts when the key is turned ONLY when not connected to the starter! Seriously I take my multimeter and clip the ground to the frame and positive to the signal wire turn the key and 12 volts every time. I reconnect the signal wire to the solenoid and nothing. I clip the positive from the multimeter to the solenoid with signal wire connected and nothing WHY? this makes no sense to me. Please help what am I missing?..... David
