2005 Liberty Wire Colors Downstream O2 Sensor
grant407
Sudbury, Ontario, Canada
Hi all, New member, long time lurker here. I need your help. My Downstream (post-cat) Bank 1 (driver's side) O2 Sensor Wiring harness got ripped off, and I can't seem to find a wiring diagram (and my friend's '03 had different colors)....
The colors seem to be as follows (forgive me if they are a little off, it's pretty dirty under there..):
Black w/ Blue
Blue w/ Teal
Black w/ Green
Red w/ Black
Vehicle Details: 2005 Liberty Sport 3.7L 4x4 6-speed and I'm not sure if it makes a difference but it is a Canadian Jeep.
Just would like to know which wire goes to which pin in the harness (1, 2, 3, and 4) Thanks!
grant407
Thanks for the replies, ant that service manual is very helpful. Unfortunately the service manual shows different colours than what the wires appear to be. I will check the other side tonight to see if they are the same. Cheers.
I have 02-03-04 Jeep Factory Service manuals but if 05 is different then no help to you
Eli
i am facing the same issue and manuals doesn't help me at all i can not figure it out please help me 2005 kj 3.7L
Eli
hi grant how are you doing , i am also facing same problem , did you find out the solution kindly share with me
