2008 Jeep liberty starter problem
leolike212
I have had to replace three New starters and see and smell smoke coming from that area. Have checked all relays and fuses. All good . Starting to check wires next. Any help would be appreciated. One more question could engine be locked. It did overheat due to broken radiator prior to this problem. Thanks
Take the plugs out then pop the starter out and bar the engine over on the ring gear or try a socket on the crank to turn it. See if any water comes out of the plug holes.
leolike212
What would that prove. Blown head or gasket? Did oil change no coolant water in with oil. I forgot to mention. That the starter is extremely hot to the touch. Could it be a ground issue?
DadOSix
Cumberland, MD.
So- a lot more detail would help:
1 - please describe why the starter needs replaced to begin with.
2 - why have you replaced the starter 3 x ?
3 - what are you seeing / hearing / experiencing when trying to start the jeep?
Give us the whole story and maybe it will lead to a fix. At this point, it COULD be ANYTHING because we have nothing to go on. It is hard to do a decent diagnosis without some detail. @KJowner may be following the right track in wondering if the engine even can be turned by hand.
