225/75R16 replace with 225/65R17?
tonyiiiafl
Found these. I tried 225/75R15 an wouldn't clear the frt calipers. So compared these 17's to the stock 16's. Thoughts? A tad slower speed at 65, however it will be a majority city car, very little highway use.
Current Tire Size: / 225/75R16
New Tire Size: / 225/65R17
Side by side Overlay
225/75-16225/65-17Difference
Diameter inches (mm)29.29 (743.9)28.52 (724.3)-0.77 (-19.6) -2.6%
Width inches (mm)8.86 (225)8.86 (225)0 (0) 0%
Circum. inches (mm)92.01 (2337.03)89.58 (2275.46)-2.42 (-61.58) -2.6%
Sidewall Height inches (mm)6.64 (168.75)5.76 (146.25)-0.89 (-22.5) -13.3%
Revolutions per mile (km)688.63 (427.89)707.26 (439.47)18.63 (11.58) 2.7%
Forum embed code
Speedometer Difference​
Speedo ReadingActual Speed
20 mph (32.19 km/h)19.47 mph (31.34 km/h)
25 mph (40.23 km/h)24.34 mph (39.17 km/h)
30 mph (48.28 km/h)29.21 mph (47.01 km/h)
35 mph (56.33 km/h)34.08 mph (54.84 km/h)
40 mph (64.37 km/h)38.95 mph (62.68 km/h)
45 mph (72.42 km/h)43.81 mph (70.51 km/h)
50 mph (80.47 km/h)48.68 mph (78.35 km/h)
55 mph (88.51 km/h)53.55 mph (86.18 km/h)
60 mph (96.56 km/h)58.42 mph (94.02 km/h)
65 mph (104.61 km/h)63.29 mph (101.85 km/h)
70 mph (112.65 km/h)68.16 mph (109.69 km/h)
75 mph (120.7 km/h)73.02 mph (117.52 km/h)
80 mph (128.75 km/h)77.89 mph (125.36 km/h)
85 mph (136.79 km/h)82.76 mph (133.19 km/h)
90 mph (144.84 km/h)87.63 mph (141.03 km/h)
95 mph (152.89 km/h)92.5 mph (148.86 km/h)
100 mph (160.93 km/h)97.37 mph (156.69 km/h)
Are they off a compass or patriot? The spigot on a KJ is bigger than the hole in the centre of the alloy so will need machining out to fit.
tonyiiiafl
Are they off a compass or patriot? The spigot on a KJ is bigger than the hole in the Centre of the alloy so will need machining out to fit.
Well, i errored. I have a LIBERTY and these were from a Patriot! So, the center hole was 67.1MM and mine was 71.5! NO fit, SO, I made a jig to attach to my die grinder and ground off the inside ridge, which gave me 70MM. Then using the jig I as able to grind a perfect circle out to 72.5 MM. The larger hole was for my comfort that when the wheel went on, it would be centered by the lug bolts. Worked perfectly, and those 17's are smooth and quiet!
