hyedipin said:Silent armors, you mean?
You think they will be better than other A/T s out there?
I was getting ready to get FORTERA's but couldn't make up my mind which type.. I didn't think the directional ones had enough tread pattern to cut through snow.
On the other hand, scorpions were looking good.
We also have Geolander AT +II at 245, which 1300ZUK over at LOST with exact KJ as yours got, and they liked them a lot.
Today I saw someone running wider tires on his sport. It was not only tires, I think the rims were sticking out. I was going to stop by him and ask for the tire size and to see if he was rubbing any, he turned.
hyedipin said:Costco does not let you search by size, so I have about 3 options, local tire shop, costco and sears. I just need to make up my mind on the tire size and brand.. I would prefer 235 if I can find the exact fit, if not, then there is no choice but to go with 245.`
hyedipin said:It is a spare, so I wouldn't mind having the HP as spare, it's not a problem at all. If we want matching looks everywhere, than I can consider replacing the spare as well.
hyedipin said:You might be right, but it is spare afterall, and I think it will pull you through, unless you are in high grade terrain. But I agree, it could be a bug in your ear, and could be easily sent away with extra $200.![]()
I looked around and did not see any articles anywhere with disadvantages of running larger than OEM tires.. or risks.. other than rubbing and mileage count problems.
I am still pushing for same size replacement if I can get, so I don't worry about spare or other problems. I found out that tirerack added local shop information.
thecause17 said:hyedipin said:It is a spare, so I wouldn't mind having the HP as spare, it's not a problem at all. If we want matching looks everywhere, than I can consider replacing the spare as well.
My concern has nothing to do with what brand or what the tire looks like. My concern is running the spare, which will be a half inch shorter tire than the other 3.
