Wulfhound
I meant tire size ...
It origannly came with 30's I think they were 235/70/16's I ran them for about 16-17,000 miles then bought the Cooper ATR's w/ 50% or more tread on them for 200.00 3,000 mi ago.
Is the KK geared differently then the Kj? I am asking cause y'all keep saying you need 4.10's and your running 245/75/16's or similar and I have
245/75/16's on my stock 2012 KK and I have not had any issues rpm's nor acceleration. I also still have a few inches left in the wheel well
245/75 or 245/70? Either way that's impressive. No trimming?
Another factor that comes into play here is that your suspension may not have sagged yet. How many miles on the KK?
The KKs can run bigger tires then the KJ can stock since the wheel well is different and comes with different factory options
Yes my friend was comparing his 03 or 06 i think and was tripp'n on how much space I have in the wheel well and that it does not rub at full lock:rockit: so I'm thinking when I get the lift I should be able to run 32's no problem well except for maybe going to 4.10s
:Good or Bad:
Keep your stock wheels and tires, then byt a second set of wheels (cragars on craigslist can be had for verrrrry cheap) then just run the 32's when you wheel.
I will prob keep the ones I got for now and when I can get wider wheels and larger tires as well as regear to 4.10 as I am going to create a Rubicon edition and I prefer larger tires dont care about gas milage or having a sedan like ride thats why I own a jeep:rockit:
While the wheelwells are different on a KK, 32s still take up quite a bit of room in there. We've tried them on a 2.5 inch lift here and it was real close , not much room at all. With 3.5 or so inches of lift you'll have more but ...........Yes my friend was comparing his 03 or 06 i think and was tripp'n on how much space I have in the wheel well and that it does not rub at full lock:rockit: so I'm thinking when I get the lift I should be able to run 32's no problem well except for maybe going to 4.10s
As far as gearing I had 245-70s/255-70s/245-75s/265-70s on mine before I went to 32s. None made much of a noticeable difference until I installed the 32s. Didn't even want to drive it hardly until the regear was done a couple of weeks later
Right on Tom that's good to know. I am not quite there yet but thanks in advance don't kow nething about regearing just what I read from all ya'll on hereIf I were you and going to 32s I'd regear to 4.56s
I wish you could on the KJs since with 32s, the added weight it would be about perfect all around
