2wd to 4wd???
wheelerkj
Valrico,fl
i just bought a 2006 kj 4 months ago. i am trying to find something on converting these to 4wd. i know there is the opt of buying one already 4wd. but i like this one. i just need to find out where to get the parts. selector, transfer case, linkage, drive shaft, axle. can someone tell me what im missing and where i can find it.
thanx , joe
Alot of people want to do this but its not very cost effective at all.
Off the top of my head, some parts you need:
-Tail of ******
-tcase
-front axle+cv's
-front drive shaft
-rear drive shaft
-Shifter
$=alot
wheelerkj
Valrico,fl
hp30
ive been thinking about the donor. but i heard something about somebody putting an xj's hp30 under the front and eliminating the ifs all together
wheelerkj
Valrico,fl
i have an old xj laying around. but its 2wd too. got it for 300 bucks when i was getting started
jeepkj02
Holland, Michigan, USA
So much cheaper to get a Liberty that already has 4x4 then swapping one in. Even if you do go SAS....solid axle swap...
Corwyyn
Southeast of disorder...
Ok now you got me confused...SAS...SFA....:confused:
Probably the same thing only I called it stiff instead of solid, sorry.
Yeah Tony, it's the same thing. The important thing is that the conversion from 2WD to 4WD is money and labor intensive. A cheaper solution would be to put a locker in the rear and just go see what you can do - you might be surprised :) Oh and make sure you get some armor under there, lots of tender belly pans just waiting for that *one* rock :eek:
wheelerkj
Valrico,fl
yeah i think a locker is the best bet for now. maybe in a year or so i'll trade it in for someting better. i was looking at the setup between the two and if it had a frame then yes it would be easy but these unibodys are to scary even for my crazy self
Corwyyn
Actually Jeep calls it a 'uni-frame' but the frame part doesn't help so much when you can't remove the body from it :mad: If it had an actual frame then lifts would be sooooo much easier.
Yea, a Jeep with a locker is decent offroad but you still lack 4low. I use 4low almost anytime Im offroad and i couldnt imagine not having it. Talk about a cooked ******!
J-Thompson
just south of doucheville
X2
and you will not be allowed to most organized off road events with only 2wd
but the big thing will be the ****** they are not happy with 4wd low so with out the low range I would stay on the road
just trade it for a 4wd if you want to go off road any thing else is a waste of time
