trail rated
Almost 100% of all OEM temp gauges read the same as the KJ's.
I remember hearing that certain model years got "fake" temp gauges.
They all basically operate like the KJ's since about 1996.As far as it being off the KJ has a safe operating range,the t-stat only starts opening at about 195 degrees and doesn't fully open till 218 degrees(+/- a few degrees is possible).I remember hearing that certain model years got "fake" temp gauges.
With a blown radiator side tank the engine heats up quickly.
The KJ, with it's 16 lb pressure cap, doesn't boil the coolant until 260*.
WJs, with their 18-20 lb caps, don't boil over until the coolant gets up to 266-272*.
Yeah, it sure does start heating up quickly. Not that ThunderbirdJunkie would know anything about that, what with being on radiator #4 and all![]()
ThunderbirdJunkie was more referring to the 4.0's uncanny ability to dribble whatever fluid it can find through whatever orifice happens to be available to it.
A technician at the Chrysler dealer said that engine problems are fairly common with the 3.7, 4.7, and 5.7 engines. Particularly with the valve springs, timing chain tensioners, and the heads.
I wonder if it was just a fluke? My father drives like an old person and the KJ has never been off-road.
Try swapping the ignition coil with another cylinder and see if the misfire follows that coil. Otherwise it might be another problem, valve or??
And definitely replace the plugs to rule that out!
Ok, the computer finally gave me a code for the coil so I replaced it. The Jeep now runs smoother than it ran after the last time we had the heads removed. I also replaced the drain ****, so now everything is fixed!
