jeeptorino68
Got under last night and hit the exhaust all over with my hands, etc. Couldnt get a similar noise, especially from the pre-cats. Am So I doubt its the exhaust
Hi and good morning, I'm not a fan of additives to oil but maybe as a last ditch troubleshooting move add in a quart of Lucas oil stabilizer with some straight 30wt oil and see if the noise changes. I wouldn't run straight 30wt for regular use. Just something to try since you've explored everything else. I guess on the bright side 3.7 engines are plentiful if it comes down to it.
Did you ever cut open an oil filter and see if there is any bearing material in the folds? Look for bits in the drained oil too. Use a paint filter.
I spun a #2 rod bearing around 175k in my 02. Knocked for quite a few months before it went.
