[email protected]
The water pump leaks intermittently on my son's 08 Liberty. It doesn't leak when the engine is hot; it leaks following cool-down.
The procedure I found on youtube shows first removing the thermostat, which is in a small housing on the engine side of the hose from the passenger side of radiator at the bottom. It is not clear to me why this has to be removed prior to removing water pump. Has anyone experience with this water pump removal/replacement procedure?
