Clutch replacement 05 3.7 6 spd
Greatpatch
I believe my throwout bearing is bad. I've ordered a clutch kit from Rockauto. I've got it up on jack stands and I am trying to follow the Haynes manual. Years ago I removed a transmission and transfer case at the bell housing from my 1975 Scout II all at once. Can I do this with my Liberty? I am stuck on removing the transfer case with the recessessed 14mm nuts to the transmission and might bus it to Harbor Freight to get a "go through" socket set.
04Liberty
MD
Haynes & Chiltons used to be good....crap since the 80's. Get yours:
u2slow
BC
I have taken them out separately on 2-3 occasions now.
If you have trouble getting tools on the top bolts, separate the trans crossmember from the frame and pivot the whole drivetrain down an inch. Once you have those free, bolt the crossmember back, remove the tcase, then carry on.
Be sure to grease the contact points between the fork and TO bearing. It was clear from the wear I'd missed that on my first clutch change.
Greatpatch
Thanks. I couldn't get a ratcheting box end on the transfer case nuts. I even bought a set of go-through sockets, which didn't work. I could get an open end on the nut but was stripping it. I gave up and pushed it (downhill) to a transmission shop. They removed the whole transmission and transfer case together. So $1200 later, it's running.
