4x4 at what speed?
Emoto
SE Mass
Do you move the transfer case lever slowly and dliberately with a pause in each position, or are you pulling it quickly to the desired position?
yoda13
Texas
jeepjeepster said:
i dont have the tow pack, i do have the 17in rims though, hehe. and y would urs last longer? b/c i use mine, that dosent hurt it to do what ive done, it still works fine!!
I agree with Grogie, if you are causing your transfer case to make noises like that, I believe his will last longer....
so uve never heard ur t-case pop? every jeep ive ever been in, including our 3, have popped when going in and out of 4wd.weve even got a grand with 155k on it and it works just fine, it pops all the time.
Bennett
Active Member
Green Bay
For the most part when I engage 4 wheel drive I just baby it for a block, to make sure its engaged. Because once before I thought it was engaged and it made the pop noise, since I believe the back wheels were slipping a bit.
But, Basically you want all 4 wheels turning at the same time, at the time of engagement. Making the back tires spin while engaging it, will most definetly cause the pop noise.
Bennett
yoda13
Texas
Actually I have heard it before. On one of my previous Wranglers, I heard the noise when shifting in to 4wd, and then immediately after it, I no longer had a functioning transfer case. Fortunately it was still under warranty. But hey, that is just my experience. My family and I have had a lot of Jeeps in the last decade and a half and the only time I have heard this, it was very bad, but that is just my experience. I tend to baby my Jeep when shifting the transfer case. If your is functioning well in this fashion, who am I to say that you are hurting anything? I was just speaking from my past experience.... :alien:
