6 beeps when parked
jayjayjeepboi
Hello, new to the kj and been running into a weird issue. Car has had no issues running, driving etc, but I do have where while the car is parked and I'm inside and hear the car beep (same noise as when you lock/unlock it) and it will beep 6 times quick in a row. Then it will stop. Happens a couple times a day. Only other "electrical" issues I notice is the clock on my head unit not keeping time and resetting often. Please help, thanks!
DadOSix
Cumberland, MD.
If your jeep has evic (overhead console). It may tell you. Justanswer suggests a maintenance interval needs reset. I have never had either of mine do this, so i am just spit-balling
Jeeper-Creeper
Does it do it right after starting the jeep?​
6 beeps = service reminder​
The beeps are a service reminder meaning your Jeep needs service (oil and filter change). You can reset the service reminder by selecting RESET on the display
menu when the "perform service" or "0 miles to service" message comes up. Simply
press and hold the RESET button.
Check in your owner's menu on how to do the reset and how to reset it and also how to change the interval in miles between oil changes. The reason i am asking you to check the owners manual is because the way to do it changes from year to year and model to model.
jayjayjeepboi
It doesn't not do it when I start the car, only randomly few times a day while it's outside parked.
ikuo78
Japan
Does the EVIC display anything when it beeps?
