A/C blowing heated air
sdlehman
I had started to notice my a/c unit working intermittantly recently. When I would be driving along the air would warm up. When it was hot outside. Usually it would start working again if I left it off for a little while or elt the car cool down. Now this wasn't happening all of the time, just occasionally.
Friday when I jumped in and started up the a/c the air was hot and became much hotter as I drove, as though the temp control was on hottest position. The car had been sitting in the sun while I played in a golf tounament.:) No matter what I did this did not change. I tried again yesterday but no help, still hot.
It seems like the heat control is stuck in the hot position. I think the compressor is working but the air is being heated.
Any help much appreciated.
Stace
sdlehman
Engine temp is normal. I checked just now and the compressor is spinning and the lower line is cold.
sdlehman
Just an update. I pulled the dash panel off and unplugged the wires for the temp control. Then I noticed this little pot looking thing so being curious I turned it with my screw driver. I plugged the wires back in, started up the Liberty and I had cool air again. =D>
I don't know if turning the pot helped or unplugging and plugging in the wires helped but I'm back in business for now.
Thanks to those who posted.
Stace
cowcatcher
Spokane, WA
Pot in a Liberty? I thought that was against the law. (whistle)
Well at least you are cool again. =D>
