A/C has me stumped
blackhawk
Venezuela
The best you can do is to check the pressure on high side as soon as you feel the ac is not cooling as it should. Just to discard the condensor.
siscofarms
kentucky
Finally got the right parts which took 2 weeks , :rolleyes: . But everything is as it should be . Blowing cold air at the right pressures . New condensor did the trick . I havent yet but I do plan on cutting into it just to see what was going on . Anyways . Thanks for advice . Sure Ill be back on here eventually for something else . I love my crd libbey but it can be a little odd to figure out sometimes and there just aint that many ,atleast around here .
Nice to hear back from you, so many people post on here, get a few answers and never come back.
The CRDs are brilliant, just make sure you keep up with oil changes and the cambelt service.
blackhawk
Venezuela
Good news! So, recapitulating you changed the refrigerant liquid house (where the expansion valve is located) plus the condenser?
siscofarms
kentucky
yes . had it completely apart and blowed all the lines out , reassembled with new parts , and all is good now .
Turboman280
Mesa AZ USA
Where did you find the condenser to fit a CRD? I ordered one from Rockauto which they said would fit, but it was too wide to tuck into the intercooler like it needs to.
seafish
The CRD uses an AC condensor that is also a combined AT cooler. Mopar does not make them anymore and most people are forced to replace them with an aftermarket AC condensor and then try to fit and add an extra AT cooler.
Nissen still makes the combined unit but hey are generally out of stock,
I have an extra brand new Nissen unit that will definitely fit a KJ CRD. It is sitting in my shop and I do not need it…
PM me with your zip code if you are interested and I can make you a fair deal on it.
BigMopar440
Pueblo, Co
siscofarms
kentucky
I got mine through Orileys . Took a few days to get it but it slid right in and all fittings were the same .
AC condenser with AT cooler? AT == automatic transmission?
Interesting.
The early KJ gassers have the AT cooler combined with the radiator.
Two for the price of one! This shows it quite clearly.
Turboman280
Mesa AZ USA
Yeah, I just bypassed the leaking trans cooler and installed a Hayden unit, but would like to have installed a new condenser while it was out. My old one still works though.
