A Few Electrical Questions
snakelady
I have a 2006 KJ Limited and I'm having a few small issues. One is the driver side low beam not working. I replaced the bulb but it still doesn't work. I traced the ground and it's also fine. I found the hidden panel where the relays are but I can't find a diagram of which is the low and high. I've attached a pic if someone could help with that much. I'm assuming it's a relay but I'm not sure. Another issue is the second digital display under the RPMs is not working. I would like it to. If I remember correctly, I think it shows what position the gearshift is in but I could be wrong. I'm not sure what else it shows. Now, this may be related as the gearshift itself does not light up either so I can't tell what position I'm in when it's dark. Not that I absolutely need to know but it would be helpful at times. Any ideas where to get started on that?
Isn't there a drawing in the lid telling you what the relays and fuses are?
I think you need to look in the dash fuse box to start with, hopefully just a blown fuse.
snakelady
I've already gone through the fuses and they're all good. I even replaced with a new one, just in case. There is a hidden box on the other side of the interior fuse box that houses more relays like the headlight high and low beam etc. It doesn't have a diagram as it's behind the knee block so there's no cover. That's why I took a pic to see if anyone can help me identify what relays these are so I can test the low beam. . I wish it was the fuse! Lol. A whole lot easier. . Thank you!
Have you downloaded the manuals? They are a bit earlier than your car but better than nothing. If you search on here you will find a link to the downloads.
snakelady
I only have the owner's manual, not any technical or repair manuals. I would love to have those! Where can I find them? Scribd?
CheddarGau
Lower Mainland BC
Are you in Canada or the US? I ask because the circuit will be a little different between the two. Specifically daytime running lights.
