CherokeeLiberty
I think I pinpointed the whirring noise, and it seems to be coming from the rear end. I’ll be checking/changing the fluid and going from there.
My dad is old school, he always cleans his old tractor parts, and some of our car parts with a tub of molassis I know it sounds odd he gets it at the feed storeIt works but its very aggressive, wouldn't recommend it if other derust products are available, very glad I greased the bits I didn't want the acid in contact with, it ate into any exposed metal. Stripped the rust off nicely but the Stripped steel flash rusts almost instantly when you remove it from the liquid.
Quick hit with a wirebrush and epoxy primer to follow.
My dad is old school, he always cleans his old tractor parts, and some of our car parts with a tub of molasses I know it sounds odd he gets it at the feed store and thins it down a bit and soaks stuff in there for a couple days and checks it and sure enough it eats rust off. I didn't believe it until I seen him doing it.It works but its very aggressive, wouldn't recommend it if other derust products are available, very glad I greased the bits I didn't want the acid in contact with, it ate into any exposed metal. Stripped the rust off nicely but the Stripped steel flash rusts almost instantly when you remove it from the liquid.
Mine did that, I stripped the caliper and rebuilt it with a new piston and seals, 10x more work than just buying a new one!On a trip away from home, when suddenly the left front caliper slowly seized up with a smoke show. Not a good day.
For every thing else..There is Mastercard..![]()
Jeep= Just empty every pocket.
Yeah, not sure if anyone has any comment on clutch vs electric fans. I see lot people with older models dealing with the clutch and the space limit, my 07 is pretty open since it has electric fans. I guess you have to rely on a the switch working and fan can fail, with mechanical or clutch is just moves with motor.Changed out my leaking water pump on my 05 renegade. Once I got the clutch fan off, it slipped and punched a hole in the radiator. Then had to run to the junk yard to pull a new one. Luckily the parts jeeps at the junk yard are in pretty good shape
The mechanical fan is way more powerful, handy if you are towing or working it hard.Yeah, not sure if anyone has any comment on clutch vs electric fans. I see lot people with older models dealing with the clutch and the space limit, my 07 is pretty open since it has electric fans. I guess you have to rely on a the switch working and fan can fail, with mechanical or clutch is just moves with motor.
Not sure which one is really better.
