ABS light
OZZYKJ
Sydney Australia
So I put ABS in the forum search, and NO MATCHES...... I find this hard to believe.... but anyway there it is....
Last few months, if I went over one particular speed hump, at a certain speed, the yellow ABS light, and red BRAKE! light would come on..... but clear after stopping and re-starting the car.
Now, as soon as I start the Car the yellow ABS light stays on, and as soon as I move, the red BRAKE! light comes on.
I have checked the Brake Fluid....... fine.....
I understand that the brakes still work, but without ABS...... and I also understand that I can connect a code reader..... but before I go to that expense, I know sometimes there is an easy fix..... loose wire or bent sensor to try first up.....
Any Ideas thanks.....
Birdman330
Des Moines, Iowa
Hook up to a code scanner, if you have the red brake light that could indicate something serious with the system and more than just a sensor issue.
