strange "rotational" noise like a bad u-joint
BubbaRand
seems to come from front diff - new CV axle, hub is fine - new front drive shaft - BAD noise in part-time 4x4, had to exit that fast - bad noise continued for a few blocks, then stopped but original "u-joint" sound continues - that this mean front diff is shot? Please help.
ikuo78
Japan
Check the transfer oil and differential oil.
Shake all the shafts held by bearings and check for looseness.
u2slow
BC
I drove the jeep on axle stands to isolate my drivetrain noise. (Thought it was the t-case).
After trying both 2wd and 4wd with no sound change, I pulled the rear driveshaft. Then the sound went away. It was the rear axle pinion bearings.
