ABS/Speedometer Issue
GunnerSchenck
If you'd have said no I'd have bet on the wiring above the rear axle and parking brake to the rear sensor..
But it's good that you have one.
The first thing I would do in that case then is run the abs codes with a code reader with abs function, or a scanner.
That way you won't end up putting more sensors on that you don't need, or a pump that isn't needed..
