AC Acting Up...
Smeltn
Alabama
I just had the replace the clutch on my AC as well. Had the same problem as you, then it just started making this loud metal grinding, teeth cringing sound and carried it straight to the shop and it was the clutch. I went ahead and replaced the Compressor as well while it was there.
n3tninja
Winston Salem, NC
My 02 did the same thing last Sept. Started with the smell on and off for about two weeks or so, mainly on a hot day usually during my 250mile travel to and from work twice a week, then the grinding started. I ended up replacing the whole damn thing because everywhere I called said it couldn't be replaced (shoulda came here first), but it wasn't to expensive and it works great now. :) Actually when the grinding started it was only at idle, but with the engine off you could grab the compressor pulley and feel the play in it.
kjweston
Boca Raton, FL
mind expressing what "not too expensive" is?
