Okay fellas, so I ran the gauges and here's the things I've noticed...
The compressor turns off and on every 5 seconds or so when the ac is running... Keep in mind that before I fixed my blend door and actuator, I ran the heater all winter, but it was on cold setting because the actuator was messed up.. So all winter the AC was running while blowing heat.. So there is 1 reason I think it might be my compressor is worn out...
So, my low side pressure goes from 42 ish down to between 10-20 when compressor kicks on and back up when it turns right back off a few seconds later.
My high pressure side is around the same psi (45-50) but goes up to 75 while the compressor is on.
When the vehicle is off, the pressure is at 40 psi on low side, and 45-50 on high side.
My girlfriends SUV is coincidentally having no cold air as well...
Her compressor visibly kicks on with the AC and stays on continuously, but her pressure never goes up and down and stays the same at 40 psi on low side, and 50 ish on the high side, doesn't move at all and stays the same when the car is turned off.
Thinking hers could be the compressor clutch and mine be the entire compressor?
