Air Pressure for best performance?
grogiefrog
Near Indy
I love having the EVIC tell me the tire pressure. What a cool feature! But I am saying that now, before I have rotated my tires and have had to manually reset the EVIC. Should be fun! wink.gif
lightfoot44
Idaho
EVIC
how do you know that EVIC is telling the accurate pressure? Maybe it's part of the conspiracy too! [-X
lightfoot44
Idaho
EVIC
grogiefrog
Near Indy
Re: EVIC
Usually, I use a hand held electric reader along with the EVIC. They seem to be right on together. As much as tire pressure fluctuates, if I set them to 34 to 36 cold, that should be fine. Not to rub it in, but having this option on the Limited is AWESOME!
Wow, thats alot of little guys and things. Yea, having the evic tire pressure thing is great. I use a digital reader from radio shack, and what ever i set it to, the evic has the same thing, so i think im good on psi. I put about 34-35 in mine, I try to have them the same, so when i look at them in the evic, there all 34, hehe.
lightfoot44
Idaho
the manufacturer says 33
why not just keep it at 33psi? ...it's what the manufacturer recommends for stock tires.
yoda13
Texas
Re: the manufacturer says 33
Those pressures are calibrated for the best ride in the opinion of the manufactuer. However, it is possible to slightly improve the mileage by upping the air pressure. Some also see some handling benefits.
-=JoN=-
67°20'N 14°40'E
yet another consipracy...heh...
they put in tire pressure somewhat below the tire's ratings for 'plushier' ride
I've seen a good mileage gain on higher tire pressure, closer to that of the tires max limit....
there is a whole science to PSI....if u want to get down to it, there are even recommended pressure for rwd, fwd, and awd vehicles.....and all under different situations too...
