muffinman
Anybody use these offroad? I have a very nice set off wheels I got FREE but they are 5 on 5 bolt pattern. Would like to know if anyone had trouble with adapters or spacers. Coming loose, cracking ,whatever.
That would be correct.I know almost every shop here will not touch a vehicle with wheel spacers of any kind.To much liability involved.another thing to consider is that many tire shops will not do tire work on a vehicle that is using any kind of spacers... meaning you would have to take them off before you go to the shop. if the wheels won't fit without them, better find a shop that will work on it with them mounted
They are harder on wheel bearings.
Explain how? or prove?
they load center is the same as say a wheel with 3.5" of back spacing
OE wheel = 5.5" of BS
2" spacer moves the wheel out 2" making for 3.5"
common for a TJ to run a 3.75" BS wheel and the OE wheel is 5.5"
Its common sense. Yes and a wheel with an offset/BS equal to a stock wheel with a spacer is harder on the wheel bearings than the stock wheel alone.
