Another Lift Kit Question
My guess is that with 2.5 inches of lift, the rear sway bar links should be 2.5 inches longer than stock to retain the same geometry. If they are longer than stock but not quite as long as stock+lift height, they will still be an improvement over the stock ones. I have a 4 inch lift and until I changed my rear sway bar links they were limiting axle travel and making for a rough ride. (I am running JBA links which unfortunately you can’t get anymore.)
archiacpenguin
Probably have to go custom. You wouldn't happen to have the specs for the jbas would you?
Find a Fab Shop, have them cut a new set of stock ones and add in a 1.5 - 2 inch round bar stock
That should do it
I forget anymore how long lfhowards were when we installed them exactly
