15 minutes more on unit...
Went to Autel site: Download Software version is 1.1 Checked the Disc that came with unit version 1.1 SAME. On disc is a pdf manual that outlines more info, than the unit's included booklet.
Went to KJ to check the Autel's unit's version. Unit is also 1.1 the latest. No need to bring down notebook to update, it is current.
From what I gather, a few more gauges were added, and update basically was for more vehicle's OBDII code reads capability. (compatible with more Vehicles)
For your Air Scare there is a section on IM, the vehicle emission readiness status.
As well as a host of stuff, that is beyond me regarding emissions.
Suddenly after clicking buttons I am starting to figure this bad boy out.
Like the menu, but often not sure if a single click or double click is required sometimes. Set in time, it was out. Date was fine. Will see if that holds.
Another good place to mount would be in the sunglass holder I call it, left of the 12v accessory, just ahead of shifter...fab a bracket? Easier to work with in your hands, then you don't have to reach. Not really sure if I will mount this permanently yet.
There is a way to make many adjustments, including different tire sizes, which is a factor in the distance and fuel mileage settings...interesting.
