Ry' N Jen
- Joined
- Dec 26, 2006
- Messages
- 9,242
- Reaction score
- 13
Does anyone know if a process similar to the one I've posted below will work on the KJ transmission? This process is for flushing Ford Taurus transmissions, I've done this process on a Taurus and it works really nice! FYI - I copied the process from a Ford forum.
Here's the easiest and cleanest way to change the ALL the fluid and filter.
1. You may still spill some fluid when dropping the pan. Best just spread out the oil dry before starting.
2. Jack up the car and place on jack stands.
3. Next disconnect the line on the drivers side of the aux ATX cooler. Put the ****** side line in a five gallon bucket. Attach a piece of 3/8" hose to the cooler where you just disconnected the line and place it on the bucket.
4. Start the engine and wait until the fluid almost stops. There will be a definite difference in the amount flowing out.
5. Stop the engine.
6. Start loosening the bolts on the pan. There is still 3-4 quarts in the pan. Position a drain pan under the ****** pan and on the drivers side. Loosen and remove all the bolts but two on the passenger side. This will let the drivers side tip down as you then slowly loosen the remaining two. After the pan is mostly down and the fluid is in the drain pan remove the pan completely and replace the filter. Be sure to remove the rubber ring that will stick up in the ****** filter mount. Just bend it in with a screwdriver and pull it out with a needle nose. Do not scratch the aluminum ****** filter holding housing.
7. Reusing the OEM gasket and in a three pass sequence progressively tighten every other bolt until all are tightened. Do not over tighten as they really just need to be snug. Use a 1/4" ratchet drive socket.
8. Then add 10 quarts. Start the motor and wait until it almost stops pumping fluid out or until you see new fluid coming out. Better to waste a quart or two of new fluid to insure all the old stuff is out.
9. When the flow has almost stopped, shut off the engine and reconnect the hoses.
10. Add 5 quarts, idle motor, put the shifter in each position pausing for a few seconds in each position and return shifter to Park. Check level keeping it on the low side on the dipstick.
11. Then drive the car for a while to heat up the ****** fluid and recheck
and top off the fluid.
I called a friend of my old boss after reading this, this morning... He has been a mechanic for FORD for the last 40 PLUS years...
And this is what he had to said after reading this BULL CHIT!. And I'll leave out 90% of the bad words!
"This has got to be the most Effin ridiculous thing I have read yet!
No wonder people say
Found On Road Dead!"
And I totally agree!
But, what ever blows your hair back.
It's your transmission and your money!
I think I'll stick to bringing our KJ to a Chrysler dealership for a proper professional transmission flush for the $300.00 they charge instead following
the above instructions from The Mickey Mouse Technical Institute!
