Ball jointed sway bar links
QRSTSaved
God is Good
Central Texas
One concern.
To adjust the diameter, a flanged collar seems preferable.
This way, the tightening force of the nut will be applied to the collar and the collar will not wobble in the hole.
I hope it goes well.
Here's the Whitelines so you all can see if you wanted.
Godbless!
ikuo78
Japan
Yeah you’re right, i’m gonna try these
Iron may be better because the tightening torque is higher.
I tightened it with 120N・m.
ikuo78
Japan
I might try these if my idea doesn't work however those bushing here are adding more thickness on the outside of the bolting points via sway bar and LCA. So idk if the Tien brand ones will work with these due to the super short stud, maybe these whiteline ones I picked up they have a pretty long. Stud
Since Tein is M12, a collar was not necessary.
Also, since a washer with a thickness of about 2 mm is placed on the ball joint side, it is possible to replace the washer with the collar.
I am not a Tein salesman.
QRSTSaved
God is Good
Central Texas
So the whitelines work! That said. Could you link the inserts that fit a 10mm stud? The 14mm outer diameter inserts I got were a mm too thick.
QRSTSaved
God is Good
Central Texas
Updated pics of whiteline links.
ikuo78
Japan
I don't feel the need to align the centers.
Below is a steel.
In your photo the screws look short.
T-series tightening torque cannot be tolerated unless there are at least 5 threads.
https://www.amazon.com/Flanged-Bear...1b0vCENaC-5MvtE7krg-pcM9kCIU4VVeq5JiomQJQD5Of -_fVeaBS64dq_igAKxUqaZUienoADe1N2bth1Pa7UL0_p4DeLS_ankw_WSjgrvkIwTMPnTU3dfM-3sCvwny46vfzaNvI8EiV0JKeIBp5J7nvAuZOj6UZkaUr101QvvJxbA1-AEC3rwH8j7.uni2 c5gMISD6zfjxxiAA8hLXAZ-xovA5BCP_ZDsbNTc&dib_tag= se&keywords=Flange+Bearing+id+10+steel&qid=1718329023&sprefix=flange+bearing+id+10+steel%2Caps%2C319&sr=8-63
QRSTSaved
God is Good
Central Texas
Below is a steel.
They are the same length as your studs. And I torqued them down. Little more than 5 threads.
wheeee32
Not the mountains.
Installed the Tein links on mine two days ago. Good so far. I torqued everything after driving around the block. Eliminated some of the noise I'm having on the front end. Still have another clunk on bumps and a creaking noise when turning while barely moving or backing up. I'll get that sorted soon.
vlad588
Vancouver
I had some time now to try out the ball jointed sway bar links and i have to say what a difference! The Jeep handles A LOT better, especially when going over bumps. Suspension just feels a lot smoother. Plus it eliminated most of the front end noise. So if anyone is thinking of installing these i would highly recommend it.
