BCM Interchangeability
Gwraalstad
I have a 2003 liberty 3.7 with a BCM # 05093038AA. I went to a U-pull-it scrap yard and found a 2002 and a 2004 BCM # 56010420AH. Paid $20 each. Great Condition. Is this number interchangeable with my 2003? They are a year before and after. Is there something about a 2003 that they have a different BCM #. Each vehicle I pulled the BCM's from were identical with mine PL/PW/RKE/Fog Lights etc... And I also pulled a BCM ($20) from a 2005 # 56010545AM. Can any of these replace my 2003 BCM as a plug-and-play. I got a quote to remanufacture my 2003 BCM for $150 from Module Experts. With shipping and handling it's $200. All suggestions/help will be appreciated.
Each BCM is programmed to that one particular vehicle
There are companies that you can contact with your VIN and they preprogram one for you so it is plug and play
I have done that a few times, once for one of mine and a few for customers
This is where I got all of the ones I used , like I said give them your VIN, and in a few days you have one in your hands. Easy to install ,send old one back and done
+1-800-245-8613
Monday-Friday 9am-6pm EST
Gwraalstad
TX very much.
Called Car Computer Exchange. They don't repair Jeep BCM's just PCM's. I know it is the BCM because I swapped out a 2004 BCM and finally got low beams but when I went to test the high beams, I got a lot of flashing lights on my instrument panel and no high beams. Maybe I just need that one reprogrammed for my vehicle. A local programmer said that because of the type of key (hard black plastic end with a separate RKE fob) that I have he could not reprogram it. Any suggestions.
Jhkj04
2004 kj
kcmo
If car computer doesn’t do bcm who does? I think mines bad. Chasing a bad grounding that only goes away when I pull the bcm out.
