Springs are good,
shocks ( only rear come with the kit) are not good at all only hydraulic not gas charged even
So you are basically buying 4 springs only
Still need all 4 shocks
We've installed one BDS ( with all 4 Bilstein shocks) rode well but he ended up as much as he would of with a full OME lift
Complete OME 835.70 from jeepinbyal
4 shocks, 4 springs
or just buy the 4 springs 927 front / 948 rear
and go with Bilstein shocks for cheaper setup
you can buy all 4 springs for 336 much cheaper than the BDS
then the 4 shocks, get stock for the front, rear for 99-04 dodge Dakota 4x4 (shockwarehouse.com)
4 shocks as mentioned above from shockwarehouse would be 416.00 plus the coils making it 752 using OME coils/ Bilstein shocks
Plus OME 927/948 combo gives you a solid 2.5 inches of lift even with no additions
JeepinByAl
Bilstein - KYB - Rancho - Monroe - Edelbrock Automotive Truck Shocks and Struts - Shockwarehouse.com
jeepinbyal also sells Bilstein shocks
IF you tried to use the rear shocks for a while with BDS and new front shocks from Bilstein you would have about 700
So just some options for you
Hope this helps some
Rev. Mudd done and standing aside
