ThunderbirdJunkie
Bronze Supporter
If he is getting 15 MPG with a 1,000lb trailer he's doin alright.
T By the way what transfer case do you have? selectrac which has two high range settings and command trac which has the high range only and both have the low range.
I have the selectrac, I have the two high modes. I think one says HI-PART ; the one says HI-FULL
Your PCM/TCM is programmed for the stock tires(even if speedo is off) and running different sized tires will throw the EVIC way off which is rarely correct anyways.Always hand calculate mileage,don't rely on a computer to do it for you.
So I will this fill up, fill up the tank to see what kinda miliage I get.
I was cleaning the truck, and I found that it actually has 245/65!!!
My consol says im getting 14.7L/100KMS...so its slowly improving, the more I drive, the better it gets.
