-4.10 gears.. Not required, but a good limited slip or locker.
-HD fan clutch with the clutched fan
-Bigger transmission cooler and/or PML pan. Mine runs a good bit cooler with just the pan, so Ive not put a bigger cooler on it.
-Good trailer brake controller.
-Depending on the size of the trailer, trailer sway control. This made my KJ feel more stable when towing than it does when not towing.
My KJ will easily tow 3,500 lbs with this setup. If I had to tow more than that, it would be much harder on the engine/trans. I can maintain 65 mph on a 6% grade in 3rd. Steeper than that and the drivetrain is screaming.
I once pulled an 8,000lb trailer and it wouldn't get above 35mph at WOT in 2nd. Going down hills were very scary and required constant trailer brakes to keep it from wagging.
