Breather lines
KingKJ
The Rock Spotter
Utah
Does anyone know how many breather lines the first gen liberty's have and where they are located(differentials, transmission, etc.) I want to raise them higher when I do my lift kit just so I don't have to worry about it later.
Also what would the process be to extend them?
Shankster
Durango, Colorado
I believe both diffs and transmission have breathers. My rear diff's was dry rotted so just replaced it with some hose from Autozone. I think rather than extend that one you should just replace it - it's pretty short anyway. I don't recall exactly where the front diff and transmission breathers vent but just look for a couple of open ended hoses in the engine bay, or trace them up from the diff / trans. Again, it may just be easier to replace them than extend them. Are you planning on fording deep water? I never worried about it when I did my lift. Assuming you know that you'll need to modify the hydraulic brake hose mount at the rear axle or else you risk ripping it off at full flex. Not sure if there is a height of lift beyond which you risk the front brake lines? Mine seem OK with a 3ish inch lift.
KingKJ
The Rock Spotter
Utah
I'm planning on 3 inch lift and don't plan on deep water, but better safe than sorry
The landrover enthusiasts round here extend all the breathers to the airbox for deep water fun.
