My '04 3.7L Liberty with 123,000 miles set code P0300 for multiple misfires. After checking it out I found that it had low compression on #4. It broke the #4 intake valve spring which was preventing the valve from closing fully. I applied shop air pressure to the cylinder and could not get the valve to seal even when I pried up on it. I've pulled both heads and everything looks good except the one spring. The broken coils bound up preventing the valve from dropping down far enough to it the piston or the rocker arm from coming out of place. The valve seat had a bit of carbon on it and once it was cleaned out the valve and seat have nice consistent contact all the way around.
My question is this: has Chrysler updated the springs? Is it worth it to replace all 12? Does anybody make a good aftermarket spring?
I searched and found lots of info on broken springs/valves but nothing much current on the repairs other than complete valve jobs or new heads. I don't think this is necessary in my case.
Thanks,
Keith
Thanks,
Keith
