Can I Fit ANY 4.10 Gears by Just Adding ANY Steel Dana 30 Carrier into the Dana 30a “Super”?
ggrjordan
Hi, guys. First time posting here. Just like I wrote in the title.
1. I want to regear to 4.10 but since I can’t find the specific Dana 30a ring and pinion set, questions arose. Could I get away with this?
2. Also, I see some of them with the tag “tall carrier case” while others don’t say it. Are they different? Which one should I get?
3. If I can get away with this, will the master install kit for the front Dana 30a super fit both the standard Dana 30 and standard 4.10 gear set?
Can’t wait to regear. I’m averaging 15.5mpg on hilly highways. Thats with mud terrains that weigh around 50lbs each, wheel included, and a 140lbs rooftop tent. All maintenance done.
Thanks!
Liberty KJ 2002 3.7 Limited.
Tow Package.
1.5in Ironman Lift Kit.
245/75/16 Mud Terrains
Speedo and Wheel Ratio Calibrated.
45RFE Transmission.
nbas
Greece
As far as I know, only JBA Offroad was making a steel carrier, which he no longer does...
duderz7
Weiser, ID
The pinion gear is the difference. You cannot put a 30 pinion into a 30a. Search on car‐part.com. I found mine by looking for a transmission for the 4cyl knowing if I found a transmission they must have the vehicle it came out of. After I found a few I found some potential candidates made a few calls and a 4 hour drive later I had axles with 4.10s. They're out there, just not easy to find.
EagleKJ
Lurking member
Toledo, Ohio
Thanks!
Tow Package.
45RFE Transmission.
I have a set for sale on ebay with the install kit. Or if you message me maybe we can work something out. I have them up on marketplace too. I am in Toledo as far as shipping goes.
ggrjordan
I saw a few steel carriers on RockAuto labeled Dana 30 under the liberty section. So maybe any of those would work, then? Since they’re steel?
ggrjordan
I’m interested .
ggrjordan
I know I can’t fit regular 4.10 gears into the Dana 30a super. My question is if by installing a regular Dana 30 steel carrier such as the ones offered on RockAuto, could I then install regular dana 30 4.10 gears. And also if said Dana 30 steel carrier can even fit in the Dana 30a super?
Thanks again for your replies.
I don't think you can put 30 bits in a 30a, there is a guy on here building a steel 30 front from a modified rear, he's put lots of information on.
EagleKJ
Lurking member
Toledo, Ohio
No the dana 30a gears and parts are the only that fit in the jeep liberty dana 30a. And they only made up to 4.10s of those. SAS is the only other option for the front which requires alot of modification and fabrication. I looked into all this when I installed 4.10s in mine.
david8
So I can't use a JK non Rubicon Dana D30 R&P gear set in my Dana D30A Liberty ?
I've heard other people using 4.56 ratio R&P gearing on the Liberty so where do they buy them from ?
I've found a link but keep reading that I can't use a Dana D30 R&P into a D30A but this link suggests it fits a JK non Rubicon plus a liberty.
I really want to regear but don't know what to purchase.
u2slow
BC
Correct.
No. There is no 4.56 for the KJ front.
Yukon has the KJ 4.10 gears. They are on Amazon.
vlad588
Vancouver
I wonder if enough interest is gathered, JBA can be persuaded to build a batch of steel front diffs
u2slow
BC
I have to admit, I'm over the steel diff idea. I ran a locker for while and didn't break anything. 311,000km now with half that on 3" lift - and no broken housing. I also keep a spare one just in case.
duderz7
Weiser, ID
I've also not had any trouble with the aluminum diff and an LSD. I take it off-road and get the occasional wheel in the air. I also drive it like a jeep, not a Baja or KOH competition.
Just for info in case people are reading this, the references to JK D30 4.56 gears in a Liberty are for the KK not the KJ. The 08-12 KK has a different style front diff, and I have never heard of anyone mounting a KK front diff in a KJ successfully. I wish you luck in finding a KJ front diff with 4.10’s from a junked 4-cylinder! That would be the easiest swap.
