Catalytic Converter Help
Hapster
Chicago
I did use NGK. I'm going to replace both downstream sensors before I change the cats. Anyone know if they would be cover under warranty?
blanchae
I just got a 0420 and 0430 code on my Liberty. Is it possible for both of the cats to go bad at the same time? Could it be something else causing those codes?
Old post but not likely. One code for one cat and O2 sensor pair and the other code is for the other side. I've had both codes pop up when I've pressure washed the engine compartment or there's been a heavy rainstorm and the wiring/connector which is common to both got wet. Dried out, erased code and good to go.
blanchae
I was just researching receiving both codes and came across your question. Just checked under our new used Jeep Liberty and it is throwing both codes because the previous owner cut out the cats and replaced them with straight pipes. I was checking the exhaust for leaks because it is a little bit louder than stock and smells rich.
