Change your oil!!!!!!!!!!!!!!!!!!!!!
osufans
Central Ohio
Master Techs normally never do oil changes so there not increasing there paycheck at all by advising 3k OCI's due to there higher pay and skill is wasted on doing oil changes.
I'm a Master Tech and rarely ever do a oil change,the shop I work at looses money if I do a oil change.There are times I do oil changes but normally with other high paying jobs like intake gaskets jobs and such.
Right, but what I'm pointing out here is that Master Techs as a group, which is what you stated, reinforce the idea of 3K OCI's being necessary. While it may not be a Master Tech performing the work, the work has to be done somewhere. And of course while the customer has their car there, "free inspections" are performed to identify other work that should be performed. I'm not saying this is all bad, because sure, things are found that would otherwise be a hazard to the customer if left unrepaired.....but if these customers were extending their OCI's, and coming less frequently, then less revenue is generated on a whole.
I'm just saying, show me an independent line of research that doesn't have an ulterior motive behind it, or at least won't be in a conflict of interest when presenting said information.
You know those stupid "change oil lights" often come on well before 3k.heck in newer Jeeps with thoise nice little reminders will come on before 3k if you shift into low range.
That is true for either side.Those that are for 3k OCI's will make more money.Those that are for extended OCI's have ulterior motives also,but alot of those poeple are now changing there minds on extended OCI's in automatic transmissions and diffs.
gnp.hiker
Who Dat Nation
So your saying the Chrysler/Jeep system is flawed? Heck if I drove around town in my GMC in low range routinely I'd imagine it'd need a premature OC.
No not flawed but when in low range you are now under the severe maintenance schedule which is 3k OCI's per OEM recommendations.
Oh and GM's oil change lights are the flawed system,some never turn on and others you can never reset.
Midgear
Mcalester, OK
I had an oldsmobile alero before I picked up mah Jeep-
the alero had the LA1 3400 V6 (quite similar to the 3100, or 3.1 that is pictured) -- these engines had a very common problem where the lower intake manifold gaskets would fail, causing oil and coolant to mix with one another.
I know that you should change your oil more often than 10,000 mile intervals, but I think that this problem here was going to happen sooner or later, even if the oil was changed on a 3,000 mile interval.
several websites and forums regarding this "LIMG leak" can be found, people trying to push for a recall ect ect. - the only way to prevent damage / sludge buildup like this is to check both your oil and your coolant- if you notice any sludgyness at all, you've got a problem.
they supposedly started using newer gaskets on the lower intake manifold and the problem was "cured" somewhere in 03' or 04' ... but whatever- I drive a Jeep now.
The revised gaskets are crap also,it's just a very bad engine design.The biggest issue is Dexacool and any other OAT coolant.
loves_off_roading
York, PA
From what I have heard, changing your oil every 3k will actually cause a lot of wear. As your oil gets older the engine will wear less. But I wouldn't go over 5,000k for an oil change so you engine doesn't build up sludge. jmho
al7fi
Chugiak, Alaska
You can pay now or pay later (JMHO). One new/rebuilt engine = a lot of oil & filter changes at 3K.
It's your ride, do what you want to do! (and live with it)
MoreTorque06
Waukesha, WI
I change mine every 8k-10k or so. 121k and counting on my 2006.
I drive 80% freeway and always use a top quality synthetic oil and filter however.
incommando
SW Ohio
My Dad's '87 B350's 318 had 218,000 miles on it when he sold it...and he had me change the oil/filter every 6K-8K with whatever oil/filter combo he could get cheapest at the time. What dos this prove? Nothing.
Having to pry out the fact that the sludge in that engine was due to a contamination issue common to that POS engine makes me wonder why this subject was brought up in the first place....
Did he tear the engine apart? Nope so you do not know it did not have sludge build up as a engine can still run good with sludge buildup.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
OK Troy, I know you're the source a lot of times but this is NOT correct. I'm sitting at 3K RIGHT NOW and the oil change light did NOT come on "before 3k" and yes I have been in low range... a few times already. :D
osufans
Central Ohio
I dunno about dexacool, but DEX-Cool apparently has some issues:
DEX-COOL specifically has caused controversy. Litigation has linked it with intake manifold gasket failures in GM's 3.1L and 3.4L engines, and with other failures in 3.8L and 4.3L engines. Class action lawsuits were registered in several states, and in Canada,[13] to address some of these claims. The first of these to reach a decision was in Missouri where a settlement was announced early in December, 2007.[14] Late in March 2008, GM agreed to compensate complainants in the remaining 49 states.[15]
http://en.wikipedia.org/wiki/Antifreeze
So again...what really caused the engine failure here? Extended oil-changes, or a known bad design?
67Customs
North Carolina
The other side of the coin is that you don't know the condition of the inside of the engine either.
Not trying to be a ****, but I don't think you can just automatically assume that any engine that ran EOCIs automatically has sludge build-up.
Just fueling the discussion. I personally don't think EOCI's above 7K is a good idea personally.
I prefer a good synthetic, good filter and 5K oil changes.
Also, what if the vehicle owner had the oil changes done and specified synthetic and they used dino, or worse yet, didn't change it? Or the owner didn't even change it at all and didn't want to admit it. We were going by what the owner told the mechanic too. It (sludge) looks bad but some further testing needs to be done.
One thing seems certain, that if you used a good brand synthetic oil/filter and stuck to a oil change regimen of 5K or less and did it yourself, or a trusted mechanic, I don't see how your engine could look like the one pictured, unless something else was involved.
Just some more thoughts.
