deliciousdaly
What events led up to it breaking? My ac has been having some problems
Looks like you did this:
Which I got from this thread:
AC Compressor Bypass?
I saw that and thought it could work too, and easier as you say! But there was no mention of a belt size. Given what I went through with the belts, I could have just gone to the store and tried belts until I got it right anyways!
Edit to add, do you know how long that belt is?
Recently my AC clutch seized up on me and I figured out a new route for the serpentine belt.
If your freezes up and you can't afford to get it fixed...use these instructions on this link to get your pulley and clutch off. I didn't have the pulley puller so i used a pry bar, hammer, a bit leverage, and lots of redbull.
Sparky's Answers: 2002 Jeep Liberty Intermitent A/C Cooling
The belt you will need is a 6-rib 82.5 inch length. $28ish=D>
The attached picture shows the new route. I checked, and everything turns the right direction and I even did a 35 mile round trip right afterwards with no problems. You could probably use up to an 83.5 inch length because my tensioner pulley is at about 75% capacity....it should stretch out a little bit though. =D>
A/C was made for Georgia summers. Reminds me I need a recharge. Its not as cold as I think it ought to be.
Ry just doesnt get to use his enough up in British Columbia.
I'll jump off topic for a second being going on topic. To the person that said a man doesn't need ac, I challenge you to get into my jeep in 120 degree Georgia weather with 100% humidity when it has been sitting for a few hours and simply roll the windows down and ride without the ac..
I used a 83.5 and it worked just fineGIJoe,
I see that this post is a year old, but the AC Comp just seized up on my '02 Liberty 2WD Sport. I just want to be sure on the belt size... it sounds like 82.5" worked for you, but was your Liberty an '02?
Thanks,
David
