Clearing error codes after replacing a censor.
Mgrasso
So I just replaced my back right wheel speed censor but my dash lights are still on. Had a diagnostic reading done at the dealership and that's what they said caused them to come on. Now that it's been replaced how can I clear the code and get the lights to turn back off?
The Fixer
North Jersey
The easiest way is just to disconnect the negative terminal on the battery for 20 minutes; it'll erase all the codes,and also cause the computer to go through all the OBD II monitor checks as well.
Powerslave
Pittsburgh - Come & Get Me!
Disconnecting the battery will not erase some codes,a scanner is needed for those that will not clear.
No, but it should reset it so the MILs are turned off, till the next flag occurs.
I did that every year before emissions, so it would pass. I bypassed the EGR system on my former Dodge. 3-days before emissions testing I would reset the ECM, and it passed, EVERY YEAR. Hence, the bull-stories they are feeding us about emissions. The levels were the same as they would have been, with the EGR working.
04Liberty
MD
If you have any Superchips designed to talk to any Mopar vehicle, you can do it. I used my programmer for my Ram on our Libby. I can only vouch for Superchips on this one though.
L
lil black liberty
Guest
Just use an OBDII reader to erase the code.. I picked mine up @ Autozone for $30.. not bad considering I have used it all the way from an 01 Dodge Durango up to an 05 Jeep Liberty to an 07 Dodge Pickup.. has came quite handy as of late..
Bboyyumm
Vegas
P0122
Check engine lights bug me..So I just had my ecu read and got the code P0122.. I replaced the TPS sensor and still the light comes on.. I played with the throttle body manually opening and closing the throttle by hand and the light went off.. Then a few days later (today) my check engine light is back on again...:flame: Had the ecu scanned again and same code P0122. Any suggestions? Also when I open the throttle by hand after I let it go it makes a weird click almost like the throttle is pulling and then releasing again on its own.. Is this normal?
