Cluster gauges and main fuses or relays?
Juhkuboy
Hi guys!
I have some tricky problem with 2.5 sport.
Mainbattery get short circuit and after this short circuit instrument cluster cauges was working fine for some time.. BUt NOW
main dashboard/cauges stop working (warning lights and low gaz etc working and mileage)..
With obd reader information they all giving data and seems to be fine. There also is not found faults from obd reader and everything seems to work correctly.
So the guestion is there somekind main fuse or relay for instrument cluster cauges/dashboard? That dashboard is checked and measured and it seems to be fine but why it dont get information from sensors?
***Also is it possible being problem with mainbrain/ecu (receiving data from sensors but not transfered/sending to dashboard)?
Thank you guys and greetings from Finland!!
