Did you notice an increase in power after replacing the coil packs?Mopar 56028138af
These jeeps do not always like AutoZone stuff, but the 6 pack of duralasts cleared codes on my Jeep and have performed great.
I used NGK plugs gaped at .040 and put in new Denso Ignition coils and fixed mine, replaced sensors on the throttle body, IAC, TPS, PCV, etc - she runs fine, did this about 9 months ago, for 2003 Sport Liberty V6.
Amazon link:
https://www.amazon.com/Denso-673-5300-Direct-Ignition-Coil/dp/B01KHLJNRC
Bought all on Amazon, - have used Denso stuff since the 60's and ZERO problems.
Mopar is way overprced.
Mopar 56028138af
I've had very good success with the Standard brand.
I agree on the Mopar.I used NGK plugs gaped at .040 and put in new Denso Ignition coils and fixed mine, replaced sensors on the throttle body, IAC, TPS, PCV, etc - she runs fine, did this about 9 months ago, for 2003 Sport Liberty V6.
Amazon link:
I also had many misfires on all the cylinders shown on the scanner, - one plug was so loose I could twist it out by hand, - kept wondering why the ratchet wouldn't click, it was Autolite, plus had different brand plugs for the other cylinders, all outta gap, the coils were original Mopar - after 21 years and 193k miles they were ready to be replaced.When I changed out the spark plugs, I could see that all of the coil packs were very old.
