Frank R
Wife brought to my attention that her 08 KK has no heat. Checked blend door actuator, was fine. Started checking hoses - at normal running temperature:
1. top radiator hose is hot
2. bottom radiator hose is cold
3. hoses running to heater core are warm
4. radiator cap is cold, and can be removed with no problem
5. coolant under radiator cap is cold
6. overflow tank is empty
Please note that this no heat issue has been present for a few weeks, and during that time the vehicle has not run hot whatsoever during its use as a daily driver (40 miles per day) nor during longer weekend trips.
Any input on where to start will be greatly appreciated. Thank you.
