Well, finally done with the cooling system work. OEM coolant (HOAT), OEM thermostat, OEM coolant reservoir and purged the bubbles out of the system. Test drove around the neighborhood for 20 minutes and no leaks were detected. Also the Temp gauge reached just below the middle. Then I drove to an A/C shop to have the A/C checked and the Oil pressure light started turning on at low revolutions…..and as soon as I accelerated slightly it turned of. At every stop light going home I place the trany in neutral, the revolutions increased and light turned off.
The oil pump is new so I am thinking…could it be the oil pressure switch (its a new switch, non-OEM). I am going to buy an OEM switch by tomorrow yet I need the opinion of smarter/more knowledgeable people than me. Thanks for your advice.
