Jeep Liberty Sport v3.7 2002
Could someone please have a look at these pictures and let me know if the rubber hose on the right-side is going into the correct connector? And is there supposed to be a hose connected on the left side of this intake system?
Quick backgroud of recent repair work done:
- One of the engine pistons had to be replaced (engine repair kit used)
- Steering repair kit used to fix a continous steering oil leak problem
- Radiator fan clutch and water pump replaced with new ones
Jeep has been running fine for more than a month now except for couple of issues:
- Engine check indicator is now lit up all the time (not sure if it has been on since the time after engine repair)
- The temperature does not rise instantly but if left idling for a "very long" time, the temp shoots up all the way to high. And then the raditor fluid starts boiling/spilling. But if I start moving again, the temperature goes down. I am guessing the running air flow helps with cooling.
- Doesn't seem like it's all the time but have noticed that whenever after I make a hard right-turn, there is a slight sputtering for a few seconds. Its like the jeep is running out of fuel and about to almost come to a stop. And I am having to accelerate harder to bring it back up. This only happens for a few seconds and only when making sudden "hard" right-turns (not all right turns though).
Based on the above, any suggestions/advise someone could please come up with for me to check. Mostly I am worried with the check engine indicator on.
