Second generation model 001 available now
I am attempting to post some photos comparing the first generation Hot Diesel Solutions Model 001 prototype engine thermostat assembly with the second generation Model 001 prototype.
The first gen unit was in my blue Liberty CRD since the fall of 2014, and it has performed flawlessly... no leaks, and proper temperature control of the engine, which is something I can not say for the O.E. part. Your V.M. Motori R425 and R428 engines will now operate at a proper, (read that as HIGHER), temperature, and thermostat valve change-outs will be cheap and easy to do.
The second gen unit was designed with the same attention to detail and quality the first gen unit received; the only difference between the two being the addition of extra threaded ports for easy installation of aftermarket engine temperature sending units for aftermarket temperature gauges and conversions to electric cooling fans.
Mr. jrsavoie, you now have the means to easily install your aftermarket engine temperature gauge.
arty33:
PHOTO #1 SHOWS NEW GENERATION MODEL 001 PROTOTYPE WITH 1/8" NPT THREADED HOLE FOR AFTERMARKET TEMPERATURE SENDING UNIT.
PHOTO #2 SHOWS A COMPARISON BETWEEN FIRST GENERATION PROTOTYPE AND SECOND GENERATION PROTOTYPE FROM THE SIDE THAT HAS THE HOSE BARB FOR THE UPPER RADIATOR HOSE.
PHOTO #3 SHOWS A COMPARISON BETWEEN FIRST GENERATION PROTOTYPE AND SECOND GENERATION PROTOTYPE FROM THE SIDE THAT HAS THE O.E. TEMPERATURE SENDING UNIT THREADED HOLE, (O.E. T.S.U. INSTALLED ON SECOND GENERATION PROTOTYPE). THE EXTRA THREADED HOLE IS 1/4" NPT FOR ANOTHER AFTERMARKET T.S.U.
PHOTO #4 SHOW THE SAME COMPARISON AS PHOTO #3, BUT THIS TIME THE O.E. T.S.U. IS INSTALLED ON THE FIRST GENERATION PROTOTYPE.
I have 15 extra Model 001 assemblies being made at the time of writing this. If you want one, please see earlier postings on how to send your advanced payment to me.
Best regards,
